Home > Technical > Main Beam Dash Indication Bulb
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Hi...im new here. Blame a couple of Bristol boys for me being here. Just gone from Disco2 Facelift to a 110 Defender.
Only driven it to work and back this week so not had much daylight to fiddle.
One of the first annoying things is the Main Beam indicator light on the dash didn't work. But last night and tonight it began to work....intermittently. Do others have any experience of this problem? Will it be a loose wire on the dash or is the switch known to be faulty?
Post #576976 10th Nov 2016 10:27pm
V8GPC
if its the early style that are filament lamps rather than TD5 that was a slighly more moden LED panel; then its likely to be a dodgy bulp or dirty contacts. The bults are in a holder that fit into the panel and twist through 90 degrees; the holders have contacts that make electrical contact with a platic membrane PCB.
The panel removes with 2x screws and the whole lot comes out from the front with only two plugs on the back; remove it take all the bulbs out (they are all the same) and clean up the contatcs with WD40 or a proper electrical cleaner and a light wire wool.
its the copper coloured bit you are giving a slight clean up.
Part number AEU2721 £23 from Paddocks if you decide to replace.
http://www.paddockspares.com/aeu2721-printed-circuit.html
Post #577033 11th Nov 2016 8:35am
JustFX
Well, I finally decided to have a got at this tonight.
Ordered the part, just received it. So took the dash apart and ran into a problem. LED, I have a LED board rather than bulbs in holders.
By the looks of it, I either have a dry joint or a loose wire.
https://1drv.ms/i/s!AoQU31lH3_fGg4pyEzO_vpHz7EZTQQ
Short Video,
https://1drv.ms/v/s!AoQU31lH3_fGg4pzuSbEjSYlTPW2aw
Post #618191 20th Apr 2017 7:18pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I have a similar problem with my heated rear screen tell tail LED, it flashes like mad then after 10 minutes stops altogether.
Need to get it stripped and have a look.
Will 2005 90 XS
1954 86'' Series 1 tilt
Post #618215 20th Apr 2017 8:23pm
JustFX
We have a winner. Dry joint. Quick heat up and a dash of fresh solder and its all fixed.
Post #618216 20th Apr 2017 8:25pm
derbywill
Great news! I must get mine sorted!
Will 2005 90 XS
Post #618481 21st Apr 2017 7:11pm
