Home > In Car Electronics > Slight side light problem
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
Hi all this morning I noticed in the reflection of the car in front of me that my main head lights were partly lit with just the side light being turned on. When turning on main light they illuminate properly. This is both lights not just the one side. Any ideas a dodgy earth or the switch failing. It's a 04 td5 160k. Ta. Marty
Post #576000 7th Nov 2016 10:10am
rallysteve
Nothing wrong with it.
Have a search for Dim-Dip. It was a stupid UK requirement for a few year.
It can be disabled by unplugging the resistor on the driver's side inner wing. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #576002 7th Nov 2016 11:12am
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Watch till the end for access to the relay or jump forward to the last 2 mins
 Adventure isn't paved!
Post #576018 7th Nov 2016 12:34pm
Defender marto
Thanks guys. I did not think I had dim dip. After nearly 8mth of owning it and putting led side lights on I never noticed it. Does it only work with ignition on?.
Post #576025 7th Nov 2016 1:43pm
GSLRO
Yes only with ignition on, just side lights.
I have led head lights and the reduced power was just as normal dipped so did the relay modification (took me 45mins inc a cuppa tea).
With ignition switched on but car not running, led's would flicker when on sidelights, not any more since changing the relay! Adventure isn't paved!
Post #576029 7th Nov 2016 1:59pm
