Home > Td5 > Bad MAF |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 365 |
You will find that it's a bit gutless without a MAF at low revs. For example mine would reverse off our steep drive on tickover with a working MAF, but wouldn't with either a faulty MAF or with it unplugged. In fact that was always the first indication that the MAF was starting to fail.
The general advice is do not waste money on a cheap MAF - get a proper OEM version from a reputable supplier. Dave Gracie - 2015 110 XS County Station Wagon |
29th Oct 2016 9:26am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
£70 to get a new OE, bit of a no brainer
29th Oct 2016 10:21am |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 103 |
It's not a financial issue TIGER, it's curiosity to know what are the advantages and disadvantages on not having a MAF.
I will get a new good quality one as soon as I am done with my silly curiosity... NOSNIBOD has given one disadvantage: gutless at low rev... I will look for that, thank you. |
29th Oct 2016 11:31am |
I found that there is a bigger difference between a bad MAF and No MAF then there is between a good MAF and no MAF.
And somewhere in between you have a working MAF that doesn't give the right values. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
29th Oct 2016 10:50pm |
