Home > In Car Electronics > Strange Headlights and Speaker? |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Yan
It's not unusual for bulbs to blow at around the same time. Happened to me recently (twice). One bulb blew...replaced...and within 2 weeks the other one blew. It's like they have a pre-programmed "life" Can't answer about the speaker noise tho - you sure it's the speaker and not something else (a relay or pump) behind? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
25th Oct 2016 8:51am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
Not so strange perhaps. Two bulbs made in the same batch with the same materials, shipped and handled in the same way, fitted at the same time, and suject to identical use. In a way it is quite reassuring that that they lasted the same duration.
I find that it is entirely usual for identical bulbs bought and fitted at the same time to fail at about the same time. |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2724 |
Yep, extra brightness bulbs of all makes generally claim a shorter life than standard equivalents too.
I always change headlight bulbs in pairs as it seems easiest when I'm doing one to do the other too Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
30th Oct 2016 9:36am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19609 |
David above is definitely right there, all lighting in fact should ideally be changed in pairs unless it's an emergency. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
30th Oct 2016 12:10pm |
