Home > Maintenance & Modifications > Td5 seat re-trim
Loz2286
Td5 seat re-trim
I'm considering retrimming my front driver's seat as the metal has pushed through the seat back. Anyone used one of these?
http://www.paddockspares.com/re-trim-kit-t...1-1-1.html
Any pitfalls? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #572470 21st Oct 2016 11:37am
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Yup
Done both my front seats.
The only real tricky bit is securing the bottom cover by pushing on the retaining rubber trim. The edges of which are too sharp and can actually cut into the new vinyl (don't ask how I learnt this) so I devised a bodge whereby I first flattened the edges with some sandpaper Thumbs Up
TT
Ps both seat frames also needed spot welding! "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #572478 21st Oct 2016 12:39pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
I used something similar from exmoor trim recently. It was a very straight forward process, I just followed the Youtube videos. I agree that it was a pain to get that rubber on ended up gentle tapping it with a hammer al the way around, then pulling it tight with the string. Then you hammer in a couple of finishing pins to hold it tight.
Make sure you have a good staple gun for the headrests, you fold over the cover like a present then staple it on to wood piece. Then replace the cover and screw that to hold it together. Also note that I didn't get foam for the head rests in the exmoor trim kit but tore the foam off assuming there was one in the box. Shocked so had to glue that back on!! Seems weird that they don't include that.
The foam was easy to fit, just spray the glue over let it go tacky and hold into position. Fairly simple.
My seat frames were rusty, so I took a wire brush to them back to the metal. Oiled up the mechanisms to get them running again. Then sprayed a couple of coats of hammerite straight to metal. Look like total brand new seats now and work!
The end result was really good:
Here is the videos if you haven't seen them:
Brit Part
Exmoor Trim
Post #573229 25th Oct 2016 4:36am
Loz2286
Many thanks for the replies fellas. Thanks for the links.
I'llgive the retrim a go and report back.
Thumbs Up 1999 Td5 110 CSW
Post #573357 25th Oct 2016 7:51pm
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
Just done a retrim with the Exmoor kit. The second one is easier!
Just follow the videos and keep in mind the point on ripping the trim if you get too medieval with the rubber strip.
Post #573402 25th Oct 2016 10:15pm
