Home > Td5 > Erratic idle/Nanocom diagnostic
Roald
Denmark
Hello
Whenever I'm driving and put the clutch down, the engine idles rough then cures itself in 5-10 seconds.
I got my NANOCOM evolution today and logged the engine data from a test drive.
The data from the testdrive shows a difference on the values from the injectors (compensation values?) when I hold the clutch down coasting to a halt compared to driving normally.
They change from this (normal driving)
CYL. 1 CYL. 2 CYL. 3 CYL. 4 CYL. 5
-1 0 -1 1 1
1 -3 -4 2 1
2 -3 0 3 6
2 -3 0 4 6
-3 -5 -4 6 0
to this (clutch down and erratic idle)
5 30 5 -4 -14
-10 6 -10 5 12
21 -15 15 -21 10
19 11 -9 -15 -13
-18 -24 -11 5 17
11 -14 5 -14 -10
9 11 -14 19 -5
-15 -27 14 5 23
-9 -32 17 -19 4
20 9 2 -14 -17
8 25 -16 21 -6
-6 -15 -3 -3 10
0 0 1 2 -3
-3 1 -3 1 3
-271 -776 719 -461 0
I also found about 30 faults stored in the ECU, (I have not included those that were related to ABS-A/C-MIL LAMP)
02-08 ambiant pressure circuit LOGGED
04-03 coolant temperature circuit CURRENT
08-02 fuel pump drive over temperature LOGGED
08-03 tacho drive over temperature LOGGED
08-07 glowplug relay drive overtemperature LOGGED
14-02 fuel pump drive open load CURRENT
14-07 glowplug lamp drive open load - CURRENT
15-02 High speed cranck LOGGED
27-03 injector 3 peack charge long LOGGED
31-03 injector 3 open circuit LOGGED
The last three faults disappeared after clearing, but all other returned immediately.
My defender is a 2005 MY
Any ideas to what cause the rough idle/faults above?
regards
Roald
Post #51588 7th Jan 2011 4:56pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Have you checked for oil in the red ECU plug?
Pete.
Post #51590 7th Jan 2011 5:13pm
Roald
Denmark
Pete.
Yes it looked dry from the outside. But I didnt disassemble the plug. Was unsure if I had to remove power from the battery?
Post #51592 7th Jan 2011 5:18pm
Zinke
Suppose you should disconnect the battery first to be safe. Having said that i never do.
Pete.
Post #51593 7th Jan 2011 5:21pm
Roald
Denmark
I got the red plug out. At first sight, it looked dry. But a closer look with a little flashlight revealed something shiny, looking like a little clean oil. I also looked at the engine plug. This one looked like there was a little more oil in it. But still not very much.
Does it only take very little oil to affect the ECU?
How about the fuelpump error?
Post #51637 7th Jan 2011 9:05pm
Zinke
It can be different between each engine but oil is not a good thing and it will only get worse. Normally by the time they come to me for repair there is a lot of oil in the plug but im sure they start misbehaving with very little oil in the plug, its just people ignore it till it gets really bad.
Anyway my advice is to get the oil in the plug sorted first before you do anything else, it may not be your problem but it wont help and wont be long before it causes some problem somewhere.
TD5 fixing school day 1 - If there is any problem with a TD5, no matter what it is, check the plug and make sure its clean before you do anything else. If there is oil there 9/10 times its the route of the problem.
Pete.
Post #51645 7th Jan 2011 10:24pm
Glynparry25
Tip 2 for the day- Best way to clean oil out of a plug is with an air duster (compressed air in a can used for cleaning keyboards etc). Thumbs Up
Glyn Sheep
Post #51648 7th Jan 2011 10:33pm
Roald
Denmark
Hello again
I just had a look at my log file and saw that my air flow values (MAF) is around 14-16 at idle and 40-50 when driving under 2000 RPM
Isnt that a bit low, I have read that 50 at idle should be normal?
Post #52057 9th Jan 2011 9:05pm
Zinke
"At hot idle, settled after 2 minutes, should read minimum 48 to 55 Kg/hr. 30 to 40 is not acceptable. Cleaning MAY help, but after cleaning and no change replace MAF. Interestingly, the reason I say rest engine at steady idle for 2 minutes is that I have observed a few engines that after a rev or two will dip below 40 for about 30 seconds or so and then back up to 50 or 60. Some may even reach 65, which is the higher end of the idle readings I have observed.
Mid throttle, (No load, in neutral, 2500 to 3250 - odd rpm) 150 to 250 depending on mapping, the higher figure for advanced performance maps is quite usual.
You can spike the figures to 550+ under no load conditions with a build up to 3000rpm and then a quick rev to 4000rpm . This is a quick indication but ideally driving on the road will show AT LEAST this reading even under moderate throttle if climbing a hill with a healthy MAF output.
The inability to reach 550 to 650 under any conditions is a fail. Clean and try again, if no change replace MAF."
Cant remember where i copied that from now but saved it on my computer as a word doc for future reference.
Pete.
Post #52061 9th Jan 2011 9:17pm
Roald
Denmark
Zinke wrote:
"At hot idle, settled after 2 minutes, should read minimum 48 to 55 Kg/hr. 30 to 40 is not acceptable....
thanks Very Happy
I have logged 15 minutes of driving, which includes accelerations to 60 mph and the MAF values is always 15-17 at idle and max 120-150.
How do I clean the MAF sensor? Can I use brake cleaner?
Post #52062 9th Jan 2011 9:27pm
Zinke
I would say with those readings that you will need a new MAF but always worth a try. Best stuff to use is electrical contact cleaner if you can get some, most car part places should stock some (the best ive found is made by loctite). If you look down it there are 2 very small coils of wire on posts that stick out from the side, its these tiny coils you need to clean. What ever you do though, dont touch the wires! If you have a K&N filter they dirty up these wire very quickly with the oil vapour coming from it.
Pete.
Post #52070 9th Jan 2011 9:57pm
Roald
Denmark
Pete.
I am going to order a new one - the cleaning is just until the new one arrives.
In the 'service' thread you mentioned a siemens MAF at half price than the landrover part, do you know where to buy it or have a part number? Mr. Green
Post #52074 9th Jan 2011 10:02pm
Zinke
Here is a pic of the MAF with the inner guard removed showing the bit that needs cleaning.
The land rover part number is MHK100620 and is cast into the plastic of the MAF. Along with this is some other numbers which are the siemens own part number. If you take this number to your local siemens stockiest they should be able to help Although i cant remember how many we had to buy to get them cheap. If you have any problems finding one let me know and i will see what i can get for you.
Pete.
Post #52080 9th Jan 2011 10:24pm
Zinke
Just seen your from Denmark, as Simens is a german company you will probably find it easier to get one over there than i will here! lol
Pete.
Post #52081 9th Jan 2011 10:29pm
Roald
Denmark
Nice, thanks for the help Thumbs Up
Post #52091 9th Jan 2011 11:07pm
