Home > Td5 > Unconnected Tube? |
EGR
Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 3rd Oct 2016 7:28pm. Edited 2 times in total |
3rd Oct 2016 7:20pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
That looks like part of the EGR system to me.
EGR has probably been blanked off but I not sure what should be done with that pipe. If nobody else solves the problem I will check mine in the morning as the EGR has been blanked on it. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
3rd Oct 2016 7:23pm |
hunter_pa Member Since: 15 Aug 2016 Location: Northern Ireland Posts: 18 |
EGR? Even if I did know what that is I wouldn't know... |
3rd Oct 2016 7:26pm |
Exhaust Gas Re circulation.
To reduce emissions some exhaust gas is fed back into the inlet manifold. Blanking the system on a TD5 makes it run smoother. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
3rd Oct 2016 7:31pm |
Exhaust Gas Recirculiation
The yellow line traces the pipe the leads to nowhere if that helps Bob. Click image to enlarge Last edited by hunter_pa on 3rd Oct 2016 8:13pm. Edited 1 time in total |
3rd Oct 2016 7:36pm |
Click image to enlarge Click image to enlarge Click image to enlarge if you look at the pic you see your pipe work go to the side air filter box one end and other end ge to EGR control |
3rd Oct 2016 8:12pm |
Thanks dorsetsmith. All reconnected. Need to be a little more careful when fiddling about in the engine bay then
Was running the conduit down from the dash to battery box for my mud pod wiring. |
3rd Oct 2016 8:25pm |
