Home > Td5 > Clutch problems
Roald
Denmark
Clutch problems
Hello
I'm a new owner of a 2005 MY defender with 84000 miles on the counter.
Each morning when I start the car and depress the clutch there is a noise. The noise fades a little when the clutch is fully depressed. When I then try to put it in (any) gear, the same noise returns.
If I then wait about a minute with the engine idleling, (not touching the clutch) there is no more noise when I depress the clutch and it goes nice and easy in gear? And the problem does not return until the car is cold again which usually means next morning. It shifts otherwise really nice and there is new MTF94 oil on the main gearbox.
Any idea whats wrong?
Regards
Roald
Post #51106 4th Jan 2011 11:21pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I think I know the noise, it is probably the spigot bearing/bush. Totallly separate from the gearbox oil. This is usually in the back of the crank and is lubricated by grease or a self lubricating material.
Mine does it too and has done since buying the car, horrible noise.
Shouldnt cause any problems and when the clutch needs changing eventually I shall make on out of something fancy ( http://www.lubroglide.com/ )
Steve
Post #51131 5th Jan 2011 8:38am
Roald
Denmark
Steve
I have read about spigot bearing noise but how can't see why the exactly same noise occurs when I try to put 1. gear in. It feels like putting it in gear while the clutch is not depressed.
I would think the clutch is worn down but why does it all work fine once warm?
Post #51138 5th Jan 2011 10:20am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
My 90 does this too, only when cold and only for about 200mtrs of driving, then its fine until the next morning. It makes a whirling noise when you depress the clutch.
Been driving ok for months with it.
Post #51139 5th Jan 2011 10:40am
Roald
Denmark
sounds like mine, but do you also have problems getting into gear while it makes the noise?
Post #51140 5th Jan 2011 10:57am
Paul_1978
Roald wrote:
Sounds like mine, but do you also have problems getting into gear while it makes the noise?
I havent noticed a problem getting into gear, some times hard work out of reverse into first, but nothing im worried about.
Good old saying, "Let it develope!"
Post #51154 5th Jan 2011 2:18pm
Steve B
maybe it's a coincidence?
Does your clutch need bleeding? Try pumping the pedal before engaging the gear
Post #51157 5th Jan 2011 3:25pm
Roald
Denmark
I have tried pumping it, but it unfortunately makes no difference
Post #51180 5th Jan 2011 6:26pm
110ross
United Kingdom 2001 Defender 110 Td5 CSW Chawton White
Hi.
Mine has done it in cold weather since the clutch was replaced and a new spigot bearing fitted 18 months ago; no other issues though so probably no need to worry.
There's no noise at all in warm weather.
Ross.
Post #51199 5th Jan 2011 8:05pm
Roald
Denmark
110ross wrote:
Hi.
Ross.
You're all probably right.
We have about -6 deg celcius here in the mornings. I tried letting the webasto engine heater run for an hour (indirectly heating the clutch area) before starting the 'fender and no clutch sound + no problems going into gear... So its definitely heat related.
I'm just going to run it as is.
Thanks for all the replies.
Post #51589 7th Jan 2011 5:07pm
Roald
Denmark
A quick question, is the clutch fluid supposed to be brown like mud or is this a sign of old worn out fluid?
Post #51694 8th Jan 2011 11:45am
Laurie
There's an upgrade to the spigot bush introduced between 2005 and 2007.
Apparently earlier ones could break up.
Post #51699 8th Jan 2011 12:12pm
Roald
Denmark
Thanks, thats nice to know.
I was googling 'spigot bearing' and came op with this thread
http://forum.landrovernet.com/archive/index.php/t-139626.html
I think my problem is described by this post in the thread
If the spigot is a bush, they can wear and the shaft drops a bit, that causes drag.
If it's a roller or ball race, they can seize or collapse. you either get drag or cannot get gears as it won't let go of the shaft and the flywheel keeps turning it.
An easy way to decide which bearing it is is the thrust normally makes a noise when you press the clutch and it's under load. If you engage a gear and hold the clutch down, if it makes a noise, it's the spigot bearing.
As Simon says, a seized spigot bearing will stop a gearbox coming off. I've seen a few boxes that have been smashed to get it off the engine.
My bushing might be worn to the point that it causes the shaft to turn with the crankshaft even though the clutch is depressed, which causes the difficulty of engaging gears.
Any things I should be aware of before starting a clutch and bushing replacement on the defender considering that I only have changed one clutch before (on a Corvette Stingray)?
Post #51729 8th Jan 2011 3:40pm
