![]() | Home > Puma TDCi > SSM38428 - P1169 and or P0089 codes logged. |
| Eduardo Joined: 28 Aug 2008 Location: SANTIAGO - CHILE Posts: 87
This issue has been commented here, but I think that can help somebody.
| CapeLandy Joined: 21 Jul 2008 Location: Cape Town Posts: 90
Excuse my ignorance but does this look like 40cc |
| dm_td5 Joined: 20 Jul 2008 Location: Northern Territory Posts: 82
50mm x 50mm x 10mm is 25cc so no its not, but that's still not a good sign. |
Do you think it is still safe then?
| TimmyNZ Joined: 05 May 2008 Location: Western Australia Posts: 24
Hi Derek, I also blindly purchaced a spare filter then found out you need one of these:
Any idea where it goes or how it works?
It plugs into the injection pump supply line on the engine via a quick connect coupling. It works as a suction pump and bleeds the fuel by sucking it through the filter, up to the engine, through the tool, and then returns it back to the tank through the fuel return line.
does that mean the outlet of the pump also has a quick coupler into the return line? |
Hi CapeLandy, here's the instructions out of the "book":
Thanks Tim, the down side to the reply you got is three letters - SPX - in my experience this spells something twice the price of Snap-On tools in Australia |
Thanks Tim
| All times are GMT |
