Home > Technical > Steering wheel vibration |
If all the above has not worked have you tried the King pins? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
28th Sep 2016 6:06am |
Gozy Member Since: 02 Apr 2016 Location: Sidbury Posts: 43 |
Thanks will check them out. Have also been told the cv joints maybe the problem but haven't any noises from them !
29th Sep 2016 10:09pm |
One other thing it could be is the steering damper. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
29th Sep 2016 10:31pm |
CamRSA Member Since: 24 Aug 2016 Location: Devon Posts: 66 |
Same issue at the same speed. I'm going to look into it as soon as I have time but any experience on here is great. I'm
29th Sep 2016 10:40pm |
I did change the steering damper about 10 months ago. That was the first thing I did. Cheers.
29th Sep 2016 10:41pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 365 |
Had the same thing a few years back and did the same things over time - balanced wheels, new steering damper, bushes replaced and so on. No change.
I then got the swivels serviced and pre-load set properly and it completely solved it. Dave Gracie - 2015 110 XS County Station Wagon |
30th Sep 2016 6:06am |
Thanks Dave seems to be the way to go. Will post the the result when done.
30th Sep 2016 10:33pm |
Finally got round to this. Started with the obvious, balancing, got lucky and it seems good to go now. Just thought I would update.
6th Jan 2017 8:23pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Some people said that a culprit are warped brake disks (I'm not sure if 2004 model have it) but worth to check. Eduardo
MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
6th Jan 2017 9:07pm |
I have that problem regularly, my problem is always the same and simply to resolve. I have regularly mud in my rims.
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
6th Jan 2017 9:26pm |
