Home > Td5 > Headlights |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
Did you change the indicator stalk, is it not that one that normally wears? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
19th Sep 2016 8:36pm |
Collydog Blue Member Since: 06 Dec 2013 Location: Stockport Posts: 26 |
Dave, thanks, but yeah, I changed that only six months ago, so it's still quite new, so hopefully it's not that, but I'll have a check of it tomorrow.
19th Sep 2016 8:41pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Do you have a cheapish multimeter? It is a good investment, just a few . You can work along the route and measure voltage or discontinuity at various points along the route from start to end, e.g. battery - fuse - relay - switch - headlamp... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
19th Sep 2016 9:04pm |
If I remember right (for a 300 Tdi), they are fused individually (left and right) so to loose them all must be something common, which I think is that switch or the wiring to it, or do you have dim/dip? 2015 RRS Autobiography SDV6
19th Sep 2016 9:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
^^^^ +1 Much better and easier for fault finding rather than replacing bits possibly to no avail. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Thanks all, just spoke with the father in law, and he's got a multimeter that I can use, so I'll see where I get with it, hopefully it's something cheap and easy to fix, thanks again.
19th Sep 2016 9:25pm |
And Dave, no dim/dip just side and headlight
19th Sep 2016 9:27pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Check ground wires and did you also check the relay? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) Last edited by 4RF RDS on 20th Sep 2016 10:48am. Edited 1 time in total |
19th Sep 2016 9:50pm |
Click image to enlarge Click image to enlarge |
20th Sep 2016 8:50am |
Big thanks to every one for you're help, and thanks for the charts Dorset Smith, I've now tested all my fuses,switches and relay, with a multimeter and they are all in order, so it looks like a bad earth somewhere, but sadly run out of good light until tomorrow, when hopefully I'll find it one way or another. Thanks again
20th Sep 2016 8:27pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
Personally I would check feeds with a bulb (I use a 21w or a headlamp bulb depending on the circuit) to load test the wiring. As it checks the wires ability to carry a current rather than just voltage.
Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt |
20th Sep 2016 9:54pm |
Thanks Will, I'll give it a try
20th Sep 2016 10:06pm |
The earth header is on bulkhead behind coolant header tank
21st Sep 2016 9:50am |
Piggle Member Since: 24 May 2015 Location: Surrey Posts: 75 |
hi, when mine packed up transpired that it was a failed relay hidden behind the dash...checked this one?
22nd Sep 2016 2:18pm |
