Home > Technical > Convert Td5 dash to puma dash |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
You will have to move the engine/ gearbox towards the rear or fit one from a Discovery as a Puma/tdci dash is closer to the seats, and an older model gear leaver will foul the newer Dash.
Also need new heater, windscreen wiper motor plus other bits, not impossible but a faff |
13th Sep 2016 10:13pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 709 |
It's like deja vu, didn't you post this not so long ago and I gave you an answer?
13th Sep 2016 10:26pm |
Thought so:
http://www.defender2.net/forum/post545491.html#545491 Without repeating myself, it's not half as hard as some people make out but as foxy red said just a bit of a faff and requires time and thought put into it |
13th Sep 2016 10:27pm |
Deslehany Member Since: 10 Feb 2016 Location: Birmingham Posts: 15 |
That's correct you did say it could be done but if you read my topic if says I'm looking for someone to do it so it's not deja vu.
Thanks anyhow lads. |
14th Sep 2016 7:43am |
Have a word with Chris at CSK, I believe he's done the conversion before. http://www.cskautomotive.co.uk/
He's based in hoddesdon, Herts. He should be able to help you out one way or another. |
14th Sep 2016 8:04am |
Thanks Buck
14th Sep 2016 8:26am |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 172 |
To my mind the main benefit of the Puma dash is the better heater / aircon system. If you don't fit the aircon then I am not sure of the advantage of the Puma dash.
Has anyone fitted aircon to their Puma dash conversion? 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
14th Sep 2016 3:21pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Another vote for Chris at CSK top bloke awesome work 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
14th Sep 2016 7:25pm |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
I'd prefer it the other way round. The heater is pure luxury. Agreed.
I have no air con. So I cannot talk about that. The Puma dash looks quite tidy (an advantage for night drivers) but far too much plastics anyway. You can have mine if you give me yours. |
18th Sep 2016 1:49pm |
Spoke to Chris and he said basically it's not worth the hassle there's to much involved
Would swap my dash no problem but if I Carnt get no one to fit it then I'm gonna have to leave it, gutted. Cheers anyhow lads 👍🏻 |
18th Sep 2016 8:53pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
Im in the process of completing a Puma dash in a Td5 with R380 with tdci instruments that all work It can be done
19th Sep 2018 9:22pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
what condition is your TD5 dash? I think I may upgrade mine to TD5, I am thinking on switching the centre console to a better unit, better Radio install and clocks etc. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
19th Sep 2018 9:34pm |
I sold it
19th Sep 2018 9:40pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
It can be done. A friend has a 300 TDI with a puma dash. He did start from scratch though.
20th Sep 2018 8:16pm |
