Home > Tdi > How much boost can a stock 200tdi discovery engine take? |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 784 |
Standard tdi runs about 1bar or roughly 14.5psi. If you want to increase boost pressure you need to look at fueling, larger intercooler, performance air filter, exhaust mods etc. It's not just a case of turning up the boost. There is plenty of info on tdi tuning around. If you do go down that route get a egt fitted as tdi's are sensitive to high exhaust gas temps, that's when things start to melt/ fail and get expensive. As with all tuning it increase's stress on the engine and other components but plenty have done it without problems and the tdi is a fairly solid lump. Mine runs 20psi boost with tweaked fueling, straight through exhaust, silicon hoses, k&n filter without any problems, doesn't smoke like a tractor and has a decent egt.
12th Sep 2016 5:59pm |
