Home > Technical > Stiff suspension advice required |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Gnasher
The standard spring rates are here (see page 2 of the thread): http://www.defender2.net/forum/topic13312.html However these may be for Puma... This is another useful link I found: http://bilashakaflowers.com/LandroverSprings.htm I've just bought a few things myself - see: http://www.defender2.net/forum/topic49065.html Hope that helps you... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
9th Sep 2016 8:03am |
Gnasher141 Member Since: 19 Feb 2015 Location: Hemel Hempstead Posts: 28 |
Martin
Thank for the reply and links That's really confused me, I think I may just try standard medium duty springs all round?? |
9th Sep 2016 4:03pm |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
My vehicle still being under warranty I do not want to fiddle with the OEM suspension.
I did find that dropping the wheel pressures to 1.8 Bar all 4 had a beneficial effect - especially unloaded. The recommended tyre pressures are only a guideline I think - as tyres do differ in their own inherent sidewall and carcass "hardness/softness". Found the following link very informative: https://www.expeditionexchange.com/ome/indexsprings.php |
9th Sep 2016 8:09pm |
Hi Sadi
Thank for reply and link Reading though the link it's saying if I have a winch bumper and winch I need to get heavy duty rated springs at the front, and medium duty on the rears as it has no load except my 45kg dog. Does this sound right? Surely 2 fat blokes don't weigh more than winch and number. Mmmmmm |
9th Sep 2016 8:29pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
You need four Defender 90 rear springs as h/d fronts are the same as standard 90 rears. Your winch and bumper doesn't weigh more than 2 fat blokes but does sit ahead of the front axle ! 2005 Td5 90 XS
Steve |
9th Sep 2016 8:47pm |
If I fit four heavy duty springs won't that make car sit ar$e up? As no load in rear
9th Sep 2016 8:53pm |
No the standard rear springs as fitted as original equipment are the same rate as the optional h/d fronts. I fitted standard rears to the front of my 300 Tdi when I fitted the winch and it sat nice and level.
There is on here somewhere a list of colour codes for all the different springs used on Defenders and their applications. 2005 Td5 90 XS Steve |
9th Sep 2016 9:00pm |
So 2 sets of these, or similar?
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwMgdX0DFc |
9th Sep 2016 9:19pm |
Click image to enlarge Land Rover used to specify different Spring rates for o/s and n/s but I think they have dropped that now as I have just replaced my rears with off takes from a forum members late 90 and they both had the same colour code. 2005 Td5 90 XS Steve |
9th Sep 2016 9:29pm |
So 2 of them ones?
And 2 of these? Click image to enlarge |
9th Sep 2016 9:43pm |
That would do the job 👍 Maybe buy some turret retaining rings for the front as the studs have a habit of shearing when you're undoing them (may be ok if you're springs have not been fitted long ago). If buying handed Springs make sure you get them on the correct side when fitting. 2005 Td5 90 XS
Steve |
9th Sep 2016 9:57pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 789 |
Do you want to keep it lifted or go back to standard?
D44 and gwyn Lewis are very knowledgable about springs and Spring rates and are worth a call. I rate and use old man emu stuff I'd try just swopping the rears to start with though. I had heavy duty on my old 90 on the rear and when I soft topped it it was very hard on the rear and I put some medium duty springs, can't remember the rates off hand and it improved the ride no end |
9th Sep 2016 10:01pm |
Thanks for advice
I'm going to Peterborough show next weekend, so hopefully there will be some retailers up there. At least I have a bit more knowledge Thanks |
9th Sep 2016 10:10pm |
Does anyone know the identifying colours for the different rate of Spring for Pro Comp?
So I can identify what is fitted to mine. Thanks |
10th Sep 2016 6:57pm |
