Home > Td5 > Hydraulic rear door opener |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 171 |
A glowing review! I'm looking at getting one of these for the very same reasons. Which one did you go for? 2002 Defender 110 CSW TD5
5th Sep 2016 10:10pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2245 |
The Britpart one....l didn't know there was a choice of makes.
But it's fine. The ram is a German made unit and the other parts are good quality. You will need a rivet gun to fit it, and the rivets are steel not aluminium so if you've a cheap rivet gun you'll need strong arms to do it....l had to use a g-clamp on the rivet gun to finish them off! |
6th Sep 2016 9:46am |
