Home > Td5 > Newbie help
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Newbie help
OK, so I have a 110 DCPU. Quite fancy one of the Scanguage II things, so go investigating on how to wire it up, before I place the order.
Now then, can I find this OBDII port? No way.
My fusebox
So without a OBDII port, I am stuck.
Options?
Post #50122 29th Dec 2010 4:21pm
NoDo$h
I thought the port was under the passenger seat by the battery on the Td5? Seem to recall my mate's 90 has an OBDII port there?
Correction: Look by the front left corner of the cubby box/tray between the front seats, next to the battery box and partly obscured by the passenger seat squab.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #50123 29th Dec 2010 4:31pm
daviec1
Cheers - 1 OBDII port located - now off to order the Scanguage
Perfect example of the benefits if this forum.
Post #50125 29th Dec 2010 5:06pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Make sure a scangauge will work with the TD5. It has some not normal protocol from what I believe.
Hopefully someone with more knowledge will be along shortly.
Steve
Post #50126 29th Dec 2010 5:20pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Scangauge wil NOT work with the TD5.
The only real alternatives for DIY use is a Nanocom or a Hawkeye, with in my personal opinion the Nanocom is far superior.
Pete.
Post #50129 29th Dec 2010 5:43pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
I don't think the Scanguage works on TD5's..........Let us know if you manage to get it working? Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #51875 8th Jan 2011 10:08pm
daviec1
Cancelled order and went for Nanocom Evolution, which should be here anyday.
Post #51885 8th Jan 2011 11:08pm
