Home > Technical > Rear step fitting advice |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2024 |
Hello Mick,
It sounds as though you've been supplied with Rivnuts - please see below: http://www.bollhoff.co.uk/en/uk/fasteners/...rivnut.php There's plenty of info on the Internet. Personally I didn't use the Rivnuts when I replaced my rear step - I drilled them out and fitted stainless steel M8 bolts. That said, if your existing Rivnuts are sound, then it might be worth running a tap through them to clean the threads up. Apologies if I've misinterpreted your post, however there are plenty of forum members who can and will lend a hand |
21st Aug 2016 10:07pm |
FarmerMick Member Since: 26 Jan 2016 Location: Shropshire Posts: 5 |
Cheers Screbble I will look into that
22nd Aug 2016 9:12am |
mpald Member Since: 16 Dec 2016 Location: North East Posts: 40 |
Hello Mick,
I have just come across your post having hit the same problem [I think]; I got the sleeve or barrel nuts through the crossmember and connected to the step, but it leaves a gap of about 10-15mm between the bolt and the crossmember, allowing the step to swing and bang against the frame. Did you manage to solve the problem? If so, how did you do it. Any suggestions would be much appreciated. Best wishes, Michael |
11th Mar 2017 7:54pm |
Hi if it is the britpart step as I had I returned it got my money back then reordered it through my local supplier and paid for them to fit it
They fitted it only to find the same problem they didn't charge me for time to fit and they retuned to Britpart and claimed fitting charge off them I then ordered a genuine one off the although was a lot more expensive it is more than capable of the job Hope that helps There were various videos on line helping etc Good luck |
11th Mar 2017 9:02pm |
It was a Bearmach step but the problem sounds identical; when the bolts and connected to the nuts, there is simply too much of a gap and the whole step rattled and bangs against the underneath of the vehicle. I shall have another look and maybe look to swap the nut and bold combination - though anything other than the self-closing nut will be a pain in the crossmember.
Thank you for the tip. Michael |
11th Mar 2017 10:00pm |
