Home > Tdi > Sports Exhaust .. |
Jampot Member Since: 01 Aug 2016 Location: North East Posts: 37 |
Anyone fitted one to a 300 tdi and was there any improvement also internal noise?
21st Aug 2016 8:49pm |
I've seen one on ebay for 115 , Regis exhausts so i'm getting one ...
22nd Aug 2016 7:49pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
I have been looking at that one.
A mate has the middle and rear and it does sound a bit gruntier (is that even a word). Apparently the turbo spools up a bit quicker as well. I have sent the chap a message to see if he can do it in stainless (my rear section is only 3 years old and shot. Needless to say it had a blue label, was dirt cheap and got me out of trouble on a holiday). 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
22nd Aug 2017 9:13pm |
I have had a message back from Neil at Regis exhausts.
Apparently he doesn't do Stainless Steel exhausts. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
23rd Aug 2017 8:53am |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
For goodness sake don't buy a double s system. had one on my V8 and it was an unmitigated pile of festering poop. The tubular manifolds were a dreadful fit on the cylinder heads and the welds cracked, the middle box didn't fit at all, was nowhere near any of the mounting points, the "Y" pipe only just engaged with the manifolds, the joint between Y pipe and centre box was forever working loose. The tail pipe came out at exactly the same place as the rear mudflap mounted on the side of the car.
Try these fellows. https://www.powerflowexhausts.co.uk |
23rd Aug 2017 11:45am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
I'd be taking a look at Alive's offerings. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
23rd Aug 2017 12:57pm |
Just had a quick look at Alives offerings and there is nothing listed pre Td5. 1995 300 Tdi Epsom Green - It's a keeper.
23rd Aug 2017 1:09pm |
Oh, I thought there used to be. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
23rd Aug 2017 5:19pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10478 |
My Double ' S' exhaust is still as good as the day i got it 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
23rd Aug 2017 9:21pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
not sure a 'sports' exhaust would have any benefit on a (probably) high milage tdi. Quite often these 'special' exhaust are fitted at a time when the existing exhaust is on its last legs, so that even a std exhaust would seem to give more power. Wallace, my 110, has a std mild steel down pipe, that does seem very thick, withoutflexi, so that is unlikely to rust, a stainless center straight thro (50) so that'll never rust,and a std cheapo rear pipe box,that lasts prob 3 years a pop, so thats 10 a year for exhausts, and prob gives as good as a 'sports' exhaust on a truck with nigh on 180k sounds good too, without being loud.
18th Oct 2017 10:17am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I paid 60 per section (so under 200 for the full system) for a stainless exhaust for my td5, think it was bosal branded. It has no cat (car was never fitted with one) and no centre silencer. I couldn't stomach 600 for basically the same thing from alive!! |
18th Oct 2017 10:26am |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
I had a stainless exhaust fitted to my 300tdi at 120,000 miles front pipe back and no centre silencer, so a "sports system". Other mods included an Alisport intercooler, injector pump optimisation and gas flowed head.
On my 110 3 door commercial there was no real increase in noise. I sold it at just under 400,000 miles over 10 years later with no sign of exhaust problems. At the time is seemed a reasonable price and was manufactured by Double S Exhausts. Hope that helps. Just because you're offended doesn't mean you're right. |
18th Oct 2017 10:52am |
