Home > Td5 > Td5 Webasto |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
Any have a picture of exactly where the dosing pump is supposed to be mounted? Looks like inside the frame rail on the right side??? I have a horrific official Webasto install guide, but the pictures are very poor and the English translation from German is worse than most Chinese instructions.
Also.....anyone have a pic of the one way valve installed on the main lines? (18mm hoses) hoping to capitalize on someone else's elegant solution before chopping up my 18mm hose. Thanks Patrick |
21st Aug 2016 12:27pm |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
In a protected plastic box fitted to rh side member close to the fuel filler pipe from where I also pick up the fuel to the pump.
Click image to enlarge I have some more pictures if you need. Regards/Hans |
21st Aug 2016 11:08pm |
Thanks! I have the manual and that pic, but I'm having trouble figuring out where that exactly is on the vehicle! I was hoping to see a pic of one on a vehicle with a bit more field of view. Patrick |
22nd Aug 2016 7:56pm |
Very nice! |
22nd Aug 2016 7:57pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Its just on the inside frame rail passenger side (LHD) opposite this spot in between the frame and prop shaft. Hope this helps some? Mine was dealer installed 16 years ago.
Click image to enlarge Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
22nd Aug 2016 9:57pm |
perfect!
Thanks...that is exactly what I was looking for Patrick |
23rd Aug 2016 2:34pm |
No problemmo. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
23rd Aug 2016 6:59pm |
