Home > In Car Electronics > OEM dash switches - where? |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
You'd have to make one
Just pick your switch type (fog or heated window) and then replace the cap with the blank |
9th Aug 2016 7:46am |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
I think a few people have had issues fitting an electric ariel due to the lack of space. Might be worth searching the forum for advice.
9th Aug 2016 7:54am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Sounds to me like a complicated solution to a simple problem, as driver9 ^ says ^, space under the wing is very limited for fitting an electric aerial so why not fit one of those stubby flexible type aerials instead ?
9th Aug 2016 8:13am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Pop a "shark fin" aerial on the roof... Not much to snag, just a slight PITA to fit... ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
9th Aug 2016 10:15pm |
On my Defender I have a vintage but bought new "Autovox SA-86" stainless steel electrical aerial manual so I can decide how extend or close. It fit perfectly.
Click image to enlarge or this types are also good RetroSound PA02 Flexible Mount Electric Aerial RetroSound PA03 Compact Electric Aerial Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Aug 2016 10:39pm |
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 |
Many thanks!
11th Aug 2016 12:39pm |
