Home > Td5 > Power to instrument panel? No odometer/trip reading. |
Click image to enlarge check fuse 15 to start with |
4th Aug 2016 8:38pm |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 249 |
Thanks DorsetSmith. I guess from the diagram I'm looking in the fuse panel behind the gear sticks?
Cheers |
4th Aug 2016 9:00pm |
that s right
4th Aug 2016 9:02pm |
Cheers.
Fuse fine, but I'm rather embarrassed to say I some how put the leads in the rear of the speedo the wrong way around...! |
4th Aug 2016 9:12pm |
with it the right way around...! is it working now
5th Aug 2016 7:08am |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
Standard design of connectors should mean even an idiot can't do this kind of thing...
So, either you're 'remarkable' or LR design choices are to blame. Solved the bowel problem, working on the consonants... |
5th Aug 2016 7:39am |
