![]() | Home > Technical > 90 Rear Mudflaps - restraint ideas?? |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
Thanks Pinky!!
![]() Perhaps my idea isn't as daft as I thought. Must get on with it. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3793 ![]() ![]() ![]() |
Our Aussie 90s have a rear exiting exhaust which creates a different issue,...at around 100kph the mudflap gets pushed up by the airflow into the path of the hot exhaust gas, which then proceeds to melt the mudflap!!
Pickles. |
Mud flap stiffeners as installed by Land Rover Hong Kong where the law requires this on front and back. Both on a 110 and on a 90. Something like this surely will solve the problem.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge More in the below thread, but those stifferers surely would look better if painted black. By the way, that special colour of this Hong Kong 110, called Matt Desert Brown is just great I think. http://www.defender2.net/forum/post160085.html Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
They look pretty good Eric, I've never seen anything like that.
The only thing I would say is that if the mudflap hit something, instead of bending/flexing,...it might instead bend the bracket? Pickles. |
That's a real off-roader talking there.
![]() ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
I tow but I've never had this. However I take mine off road and I have a small hole drilled in the bottom amd zip tie them to the rear bumper/lift handles. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
