Home > Td5 > Alarm going off around midday when the weather is hot |
Alarm interior movement sensor may be set it off if you one fitted
20th Jul 2016 3:30pm |
Telshe Member Since: 02 Jul 2015 Location: West Oxford. Posts: 49 |
Many thanks for you quick response Dorsetsmith. Would the sensor be near the roof lining behind the drivers seat ?.
What can l do to check this is the cause ? Many thanks Telshe |
20th Jul 2016 4:08pm |
yes that's the one
Do you have remote central locking ? |
20th Jul 2016 4:10pm |
Yes I do. This how l get over the alarm going off during the day. I set the alarm when has cooled down
Regards Telshe |
20th Jul 2016 4:47pm |
set it using the key as listed below
Click image to enlarge |
20th Jul 2016 4:50pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Did you leave a window open? I recently read about it's functioning in the workshop manual, and apparently it reacts to air moving inside the cabin. On hot days, I tend to leave the vents open when its parked on a quiet spot but that has never triggered the alarm (yet..?).
Greetings, Joris Edit: moving air is already mentioned in the screenshot in the previous reply. |
20th Jul 2016 4:54pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3323 |
Have you got a bonnet sensor fitted in the alarm system?
Our RR alarm used to go off when it got hot ant the bonnet expanded ever so slightly. |
20th Jul 2016 8:23pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
+1 for the bonnet trigger if you've got one!!! Easily tested though - simply pack it with something on a really hot day and see if it still activates
20th Jul 2016 8:37pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
My alarm went off at 01.30 this morning (MY2015, fitted with additional bonnet switch). All windows were closed so there should not have been any air movement in the vehicle. I put it down to the fact that it was stood in the sun all day (it reached 31.7 degrees here). Be interested to know how many more went off in the heat? Defender 90XS SW
20th Jul 2016 9:38pm |
