Home > Td5 > Drivers door lock and or key
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
Hi
Our 2004 110 CSW has a different drivers door lock to the rear door and ignition which match. I suspect due to a theft attempt at some point. How can I :
A get a new door lock to match my key
B get a key to fit the drivers side
I don't have the key number on my security card 2004 110 CSW (Called Yoda)
Post #548748 14th Jul 2016 4:06pm
dorsetsmith
Get your self new lock Barbells as you not have key number on my security card you will long time for response from LRJ lock barbells to match the key you have
https://www.famousfour.co.uk/new_parts/lr_part?part=588036 (check but i think this right parts number)
http://www.rimmerbros.co.uk/Item--i-LR077438
Is driver side lock barbells not turning with the key that you have ?
lock barbells can sneeze so that you can unlock the door with out key or sezz up so the key will not work
Post #548755 14th Jul 2016 4:31pm
