Home > Camping, Caravanning and Holidays > Bed in Defender 110 5 door
dbailey
New Zealand 1986 Defender 90 Other PU Baltic Blue
Here is my design for a bed in the Defender 110 5 door i wanted something that was very easy and simple, it only takes about 3min to convert to a bed.
The defender second row seat pivot point is changed allowing the back of the seat to pivot back(normally the back of the seat only goes forward into the bottom seat) so after releasing the seat it then goes forward as normal but the back of the seat tilts back when the bottom seat is fully forward, then as the bottom seat goes
back the back seat can then go under the seat release lock mechanism making both seats flat.
On the back of the seat i have mounted a table top, this can be used as a table and is also used as the bed base.
The right bench seat is used for the end of the bed this is easily removed, the top of the bench seat stays in place.
Please note that the brackets i have used to change the seat pivot points will be beefed up and i would like to add some locking mechanism on the left seat pivot and change that table top.
point. I just wanted to see if it worked.
The bottom seat does sit higher when as a seat after this is done, but is not that noticeable.
[/img]
Post #547508 10th Jul 2016 12:06pm
kmac
That is very cool, well done. Bit trickier to do with the Puma seats
Post #547533 10th Jul 2016 2:07pm
Crocs
United Kingdom 1999 Defender 90 V8 Petrol 50th Auto Atlantis Blue
cool!
Post #549840 19th Jul 2016 8:36pm
Cupboard
That's fantastic.
Have you seen the YouTube channel "Roaming The Outback"? He's set up a 110 with a bed a bit like that might be interesting (or not!).
Post #550588 23rd Jul 2016 10:08am
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
Yap. With Puma seats the bed unfolds just at the bottom edge of the sliding window i.e. about 20 cm higher.
Post #561341 4th Sep 2016 7:44pm
Jukathy
Post #561343 4th Sep 2016 7:48pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Post #562775 9th Sep 2016 7:13pm
VeeTee
Netherlands
Re: Bed in Defender 110 5 door
dbailey wrote:
The defender second row seat pivot point is changed allowing the back of the seat to pivot back(normally the back of the seat only goes forward into the bottom seat) so after releasing the seat it then goes forward as normal but the back of the seat tilts back when the bottom seat is fully forward, then as the bottom seat goes back the back seat can then go under the seat release lock mechanism making both seats flat.
Very interesting, but the part about the pivot point change sounds complicated, can't imagine what you did - could you elaborate on this, please? Cheers, Vincent
MySite
Post #562780 9th Sep 2016 7:26pm
