Home > Td5 > More suspension and spring questions TD5 2001 90 |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
Sorry, more suspension questions. I think I know what brands I'm going for in this department but as I will only be using main road and motorway and not towing, what spring weight should I be looking for, for a fairly comfortable ride? They can be seen listed as light, medium or heavy duty.
I want to keep the ride height standard but the better Britpart springs (yellow) are rated as heavy duty. Bilstein shocks are probably what I'll be getting. Thanks in advance Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
3rd Jul 2016 3:38pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
I would stick with the std landrover springs for your requirements 2004 TD5 Defender 90 xs station wagon
4th Jul 2016 9:47pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
If you don't want to 'stiffen' it up, If you don't want to lift it up, and it you dont want to change It's ride height ... then the advice from johnszs is the best you'll get - leave springs as standard and just replace shocks Guns and Landrovers .... anything else is irrelevant.
5th Jul 2016 12:56pm |
