Home > Td5 > Defender won't start strange dash lights |
That's a new one on me, I would be leaning to double checking the battery condition and instalation, then double checking over what you had done to prep it in readiness to waxoyling.
7th Mar 2016 11:36pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 576 |
Check grounding - between battery, chasis and engine. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
8th Mar 2016 8:18am |
L90DNY Member Since: 09 Feb 2016 Location: Somerset Posts: 117 |
I'd had taken the wings off, as new ones are going on. As I understand it the alarm is in one of the wings, so I plugged them back in and tried again with the same result. I cleaned off the earth to the chassis from the battery, and tried two separate batteries, checked them both with the volt meter putting out 13 volts, so no issues there.
Very strange, might have to get a computer plugged into it. The only thing I didn't try on the off chance might work was unplugging and re plugging the ECU in. Must some sort of weird electrical gremlin, 1 step forward 2 steps back ! |
8th Mar 2016 10:02am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6482 |
Does the ignition turn on as normal - i.e. you get glow plug light on (then off), charge warning lamp (battery symbol), dash gauges move... or not? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Mar 2016 10:25am |
Yes, lights all come on glow plug comes on and goes off. Milage shows up etc, then they all the lights go off but the indicators, fog lamps and side lights stay on.
8th Mar 2016 10:36am |
It's beginning to sound like a problem around the dashboard/switch housing by steering wheel. Perhaps the multi-plug behind the dash clocks where it takes feeds from the indicator, lights and fog light switches.
8th Mar 2016 2:17pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Are the actual lamps on as well as the indicators? My money would be on grounding. Block to chassis strap, any other grounds in the engine bay.
8th Mar 2016 2:19pm |
It is just the lights on the dash, not the actual lights that are on. I thought it was some kind of warning light sequence, but haven't found anything about it yet. I will have to check all of the grounding points next
8th Mar 2016 3:53pm |
