Home > Td5 > What is this? |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2871 |
Breather return
6th Mar 2016 1:03pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 570 |
Yup, as Ibexman said,breather return.
They get gunked up.you can replace it or clean it out. Marc |
6th Mar 2016 1:12pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Thanks for the replies, if it's something that is going to happen 'regularly', I think I'll order one from Dan and just change it over, keep the other as a spare once I've cleaned it out. Cheers
6th Mar 2016 1:17pm |
LLN100140L - VALVE ASSY - DEPRESSION CONTROL TD5
6th Mar 2016 1:25pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
Hi All, mine is in a similar gunky mess on the outside, just looking for some advice from the engine guru's . Can the valve fail internally and create the oily residue on the outside? Are there any symptoms if one fails? Should they be replaced at any stage in the engines life? Mine has 82k on the clock and I'm sure it's not been replaced before. Thanks Andy
7th Jul 2018 12:22pm |
Add in a provent!
Click image to enlarge Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
7th Jul 2018 4:27pm |
Thanks Ray I'll look into one of those, cheers
7th Jul 2018 7:39pm |
