Home > Maintenance & Modifications > Mudflap brackets
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Mudflap brackets
Hello everyone,
Before I purchased my Defender, I read somewhere that it was best to fit mudflap brackets front & rear if I was going to do a lot of driving on the motorway.
When I received my vehicle it seems that it already has these brackets fitted. Could someone take a look at these photos and let me know if they are different to the standard defender please?
If so, 1) do I still need to install a mudflap bracket, and 2) which make/model would you recommend?
Thank you in advance!
Rear
Rear
Front
Front
Post #509840 2nd Mar 2016 1:04am
mk1collector
Those are standard brackets on a 110, I'd buy a nakatenenga rear bracket plate that stops the rear bracket eventually breaking the bottom of the rear 1/4 panel. 4x4 overlander sell them and they don't cost much. Personally I'd clean them up and spray some bilt hamber uc clear wax on the metal brackets as they can rust, so a little time looking after them now keeps them nice in the future. Ray
My build thread
Post #509842 2nd Mar 2016 1:26am
APK
Thanks!
Just looking at the website, I cannot seem to find nakatenega. Is Entreq any good?
http://www.4x4overlander.com/product/entre...ainless-2/
Post #510034 2nd Mar 2016 5:19pm
MartinK
APK
You need this thread
http://www.defender2.net/forum/topic6088.html?highlight=mudflap
To explain, it's the bolt in the aluminium body panel that works loose and pulls through...not the bracket itself. Usually because the mudflap flaps in the wind at motorway speeds, or mud and crud and touching the ground when offloading cause strain on the fastening. This fastening...:
You can buy them, or make them (as I did) using a bit of aluminium strip cut to length with a hole drilled...It's just to reinforce the panel...not the bracket...The reinforcement like this (borrowed from "Red desert":
Entreq ones here http://www.4x4overlander.com/product/entre...rackets-2/
avoiding this (the mounting bolt has pulled-thru the aluminium body panel):
YRM also do nice brackets if you need them (but it's the panel reinforcement you need I think - not the bracket) http://www.yrm-metal-solutions.co.uk/epage.../008C-0003
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #510044 2nd Mar 2016 6:00pm
mk1collector
Sorry, my mistake Embarassed it's the entreq ones I meant that Martin posted a link to above Thumbs Up Ray
My build thread
Post #510053 2nd Mar 2016 6:45pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
After doing a home made repair kit on my offside one i noticed the nearside one hanging off after the Snowman Rally so i've ordered the Gwyn Lewis kit.
I'll let you know what I think once i've fitted them.
Also after coming out and finding one of the front flaps on the driveway were it had just fallen off with the wind due to the rotten bracket i replaced them with a stainless set.
Post #510054 2nd Mar 2016 6:45pm
Eduardo
APK
Happens to me in both sides after 1 year of use.
Finally I put an alloy L shape (Thickness: 1 mm, length 8") riveted to the panel and no more problems since.
Easy to do an cheap Smile
Cheers Eduardo
Post #510087 2nd Mar 2016 8:31pm
Happyoldgit
^^^ Agreed, it's an easy and cheap job to reinforce the wing lip with a length of extruded aluminium pop rivetted or Sikaflaxed in place. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #510132 2nd Mar 2016 9:52pm
Bps
They Gwynn Lewis kit is on my list to. Looks very good
Post #510141 2nd Mar 2016 10:14pm
APK
Thank you for this. I didn't really understand the issue until you sent this across. Unfortunately the Entreq reinforcing brackets in the link do not seem to be in stock.
I am thinking of removing all the mudflaps for now until I sort this out to prevent any damage to the bodywork.
Mine is a 110. Is this an issue for the front mudflaps as well, or just the rear?
Post #510189 3rd Mar 2016 1:27am
APK
Thanks everyone for your comments!
Please let me know how this goes.
Flyingfocrs wrote:
... so i've ordered the Gwyn Lewis kit.
Post #510190 3rd Mar 2016 1:31am
MartinK
That's what I did.
APK - it's probably not super-urgent - I did a fair few miles in mine before reinforcing the body panel. And Eduardo says 12 months - I'm sure loads of owners never bother and don't have a problem...
a 10cm piece of aluminium strip with a hole drilled is really about all you need (like a large "repair washer"). I have heard the mudflaps can be weakened by towing certain trailers - like a vortex of air making them flap even harder...
If I remember rightly, I replaced the nuts/bolts with stainless ones too, and lathered the whole lot in dinitrol. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #510249 3rd Mar 2016 10:44am
Very Happy
Post #510287 3rd Mar 2016 12:28pm
What I did with a section of right angle - don't see the need to drill extra holes or use an adhesive - the only extra thing i did was use a large repair washer on the underside - but that was because of the shape of the lip after just a few hundred miles with the standard fixing - from my experience I'd say do it sooner rather than later:
Post #510288 3rd Mar 2016 12:33pm
MartinK
Supacat - lovely job, and a few pence rather than £30 Smile
Similar to my own repair
Thanks for sharing Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #510317 3rd Mar 2016 1:26pm
