Home > Td5 > Clutch pedal
Cheshire Dave
Clutch pedal
Hi all,
if its not one thing its another!
Now its the clutch pedal not returning properly, I thought it felt funny for a day or two, prior to this its usually quite strong to press down but now feels much easier and sometimes doesn't return back up as it should.
any ideas guys please?
Dave
Post #509300 29th Feb 2016 5:24pm
dorsetsmith
slave and or master cylinder leaking or seal braking down color of clutch fluid black or discolor indicates seal failure or fluid contamination water and so on (clutch and brake fluid is hygroscopic)
if ever slave or master has failed, good practise to changed both as if one has failed the other one will to sooner or later
Post #509303 29th Feb 2016 5:47pm
4RF RDS
Also check your return spring it might have broken or slipped off. Item 10 in pic (if it is an older model year)
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #509316 29th Feb 2016 6:34pm
Fatboy Slim
Wales
New master and slave cylinder time.
Post #509320 29th Feb 2016 6:42pm
Cheshire Dave
Sorry guys I should have put this in TDI section but I suppose it's the same outcome, looks like a trip to my local mechanic !
Dave
Post #509475 1st Mar 2016 8:59am
dorsetsmith
same problems tdi 300 or td5
Post #509483 1st Mar 2016 9:32am
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Probably the master cylinder, but as others have said, change the slave at the same time.
Use good quality replacement cylinders, those that come in a blue box may not last very long!.
Post #509844 2nd Mar 2016 1:37am
shaggydog
Another thing it could be though I would say if the fluid level hasn't dropped it would be a good second thing it could be is the clutch release fork starting to go.
That said they usually go and go terminally- best get your master and slave seals checked first! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #509952 2nd Mar 2016 1:46pm
