Home > Wheels & Tyres > Cooper stt pro
Page 2 of 3 <123>
Guytn
Belgium 2015 Defender 110 Puma 2.2 DCPU Montalcino Red
Will do! Just got them!
To the left, the new Cooper STT pro in size 315/75R16, to the right, BFG MT KM2 in size 255/85R16!
The BFG looks a bit small Smile
Post #558357 23rd Aug 2016 5:37pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
What wheel size are you fitting these to? NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #558416 23rd Aug 2016 8:19pm
JOW240725
Wow they look huge! Want to see them fitted, I guess the suspension is lifted? James
Instagram @suffolk_rovers
Post #558447 23rd Aug 2016 9:40pm
Guytn
We will try to fit them on 16x7" or if that would not be possible 16x8".
My Defender has a 2" lift kit.
Post #558510 24th Aug 2016 7:09am
K9F
315s on a 7" rim.....no chance and any tyre fitter willing to try doesn't know much about tyres.
I am running 305x70x16 on 8" Mach 5s, no lift or bumps top adjustment and no fouling. I went from Coopers to BFG KM2s and found the noise reduction significant comparing the two variations. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #558757 25th Aug 2016 4:47am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
I'm no tyre expert, but the taller the sidewall the smaller is the influence of the rim width. Also, this topic's sensibility seems to vary from region to region. The guys in the US seem to be a lot more relaxed about this things with (at least reported) no serious problems.
But yes, a 8J wide rim would be the more conventional approach.
Anyway, are you reinforcing the transmission?
Post #558903 25th Aug 2016 5:10pm
Guytn
Tyres are performing better than the BFG MT MK2! Where the people with BFG MT MK2 got stuck, I wasn't Smile.
Post #561861 6th Sep 2016 2:08pm
Arierep
Awesome Defender Guytn!
What offset are those rims?
Post #561978 6th Sep 2016 7:39pm
Guytn
The rims are Performance aluminium TX-1. Size 16 x 7.
They are not made any longer. I've bought them second hand.
What I can find on the internet, the offset should be 7 mm. ( http://landreiziger.nl/tag/outback-tx1/ )
Post #562048 7th Sep 2016 6:38am
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
I ha e these on both my landrover and trailer and they are brilliant, all be it in a smaller size!!! Very well mannered on road and pretty good off!! Self clean well as well. On the trailer they do drag more than the old all terrains but not that noticeable.
Post #562314 7th Sep 2016 10:18pm
Harry.O
Do the 315 75s actually measure 35 inches or do they come in a bit small like the BFGs?
Post #562357 8th Sep 2016 8:37am
Guytn
You are right Harry! They are a bot smaller then 35 inch. To bad...
But they are higher then the BFG MT KM2 255/85R16.[/quote]
Post #562439 8th Sep 2016 3:20pm
gerudman
South Africa 2011 Defender 90 Puma 2.4 SW Stornoway Grey
Just fitted a set of 265/75/16s. Thus far very happy, but haven't had time yet to thorough test them offroad. Heard only good things so hoping for the best.
Post #563633 13th Sep 2016 1:31pm
Arierep
Hi Guytn
Would you mind to measure the height of the tyres without the weight of the Defender?
Thanks
Post #623469 11th May 2017 6:44pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Had mine now for 2 months and very pleased. Size is 285/75r16 on Single Side Beadlocks giving an 8.5" rim. Truck is heavier than usual due to extras and equipment.
Grip Off-Road i.e. in the fields(grass, mud, sand, etc..) far superior to the BFG's. I have quite a steep bank between two fields that requires turning 90' through a gate and climbing straight away so cannot try a run up and use momentum. The BFG's always struggled when wet and would get clogged up and stop half way up which meant the use of a big 4wd tractor to pull the rest of the way and even that would struggle sometimes. Since putting the STT Pros on I haven't had any problem.
Noise level is slightly greater than the MT2's, but the tone is different. More of a drumming sound(like you were in the boot of a car on the highway).
Roadwise, no different so far, but then I haven't worn them enough to start throwing it round the corners.
Comparison is made to the last 100,000miles done on 265/75 16 BFG Mud-Terrain KM2's.
All-in-all, I would say they are better than the BFG Mud's and soooo much better than the old STT's
Not the best photo as the sun was going down.
Post #623608 12th May 2017 12:09pm
Page 2 of 3 <123>
