Home > Td5 > Help with random tiny pipe FPR on new TD5 lump |
it is vent pipe from the back fuel pressure regulator diaphragm
the old engine fuel pressure regulator will have small hole instead works same way |
17th Feb 2016 1:06pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
Thanks mate, that has put my mind at rest !
17th Feb 2016 1:17pm |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
I've seen a small diameter piece of tube fitted to that pipe to direct any leaks below the starter motor as it can be a good way to chuff it up if it leaks.....
17th Feb 2016 7:45pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
Excellent, power of the search tells me I don't need to worry about the same thing I was wondering if the old one has snapped off or something.
That bottom knut is a sod to get to, no way of getting my torque wrench on there, was barely able to get a flexible bar onto it. Still a run round the block and there's no massive flood of fuel coming out, so I guess its acceptably tight. Did anyone else's fuel pump sound different (with the engine off, ignition on) after going through the bleed procedure? |
6th Mar 2016 6:12pm |
