Home > In Car Electronics > Defender front speakers |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1760 |
4"/100mm coaxials would be the nearest to a drop in replacement. If you want some level of improved midbass, then mounting them on 18mm MDF rings to give a solid base will help. Give the rings a coat of PU paint or something first though to protect them.
Having not looked into it properly, you might fit some 5 or even 6" speakers in there with some luck. If you really want to go for it, get components and fit the tweeters up on the dash top. |
25th Jan 2016 7:34pm |
PHIL90 Member Since: 23 Jan 2016 Location: GLOUCESTERSHIRE Posts: 9 |
OK thanks for that, I think I will stick to 100mm speakers as I don't want to start cutting the dash around to get bigger speakers in. Does the MDF spacers work that much better than the plastic ones?
25th Jan 2016 8:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19690 |
You shouldn't need spacers unless there is a lack of clearance to the rear?
Generally speaking 130mm is the max and requires some dash cutting. 100mm is straight swap like I have. |
25th Jan 2016 8:12pm |
Did you not need to pack the passenger side one as to miss the wiper motor?
25th Jan 2016 8:16pm |
Generally yup, they're just a lot more solid. Plastic ones tend to be pretty thin and the plastic resonates. |
25th Jan 2016 8:20pm |
