Home > Td5 > NO Coolant damage? Where is the Engine Temperatures Sensor? |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
Hi. I was on the highway yesterday and my coolant drained out through the same Welch (frost) Plug. I didnt realize until i saw the temp just shoot up for a second. I stopped the car and realized that there was no coolant. I drove another 20 km home, while watching the temperature guage. Does the temperature gauge only measure coolant temperature???
19th Jan 2016 9:28am |
Most do yes, in this situation I would of topped up the coolant with water to drive it home. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
19th Jan 2016 10:44am |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Diesels run hotter generally.
The OP might have gotten away with it, if the ambient temp is low enough, I note he is in Canada, so -25deg C with -50 wind-chill would definitely help in the engine cooling department. I think TD5's run cooler anyway don't they, i.e. it takes ages to warm up? Also note that the coolant would have drained to that level, so wouldn't have been completely empty. Always a chance and well, at this stage what have you got to lose?! Cheers Andy |
19th Jan 2016 1:51pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
only thing to do is to replace plug, refill, bleed and see what if any thing is up?
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
19th Jan 2016 4:04pm |
only thing to do is to replace plug, refill, bleed and see what if any thing is up? (Edit...not sure this posted twice???? Sorry).
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) Last edited by 4RF RDS on 19th Jan 2016 11:38pm. Edited 1 time in total |
19th Jan 2016 4:05pm |
37D2260L one on the head at the back and one short block alt side LCM100150 one on stort block alt side ERR6674 one on the head at the front |
19th Jan 2016 4:51pm |
