Home > Td5 > Electrickery box |
Looking at the plugs you probably need to install it between the engine loom and the connector at the front off the engine. So it will probably give you a power gain by opening the injectors a little longer.
I think it will work but won't be as refined as a proper remap. It's an easy installation and will probably not hurt your engine. The worse thing you can get is black smoke I think. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
27th Oct 2010 10:02pm |
And an increased fuel bill! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Oct 2010 8:04am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2600 |
Jah, most of these chips only overfuel your truck - increased EGT, wear & tear, etc. Rather get a remap from BAS or another reputable shop |
28th Oct 2010 9:11am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16917 |
I don't recognise the unit in the photo at all, but I do have a PSI Powerbox on my TD5 Disco and it made a HUGE improvement to driveability. Smoother power, more torque, and much improved overall driveability. No black smoke, and no discernable change to fuel consumption (in fact if anything fuel consumption has dropped since the engine doesn't have to work as hard). Been running it for about 100k miles now, and wish I had fitted it from new.
I imagine that the unit you have been offered is broadly similar to the PSI Powerbox, which is connected between the ECU and the injector harness. |
28th Oct 2010 11:12am |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 893 |
Yes it is, my friend said it did make a nice difference to the driveability of his td5 - I asked him about fuel consumption and he wasnt sure if it made much difference - the instructions say it probably will (they would!) - either way if its no good i can always take it back off and give it to him back. Its hopefully a job for next weekend then |
29th Oct 2010 7:52pm |
