Home > Technical > Engine turns over but will not firer
Zeissman
United Kingdom 2009 Defender 110 Puma 2.4 HCPU Corris Grey
Good after noon all Hope some body can give me some advice
Just tried to start the 2.4 defender this morning, the engine turns over but dose not fire, the temperature gauge is into the red but the vehicle has not ran at all this morning so know some thing is a miss, all relays have been removed cleaned and replaced, all fuses have been checked. the temperature sensor has been disconnected and tried again to start but no joy. the sensor has then re-connected,
any advise well come I don't think you understand, these boys killed my dog
I'm just a pecker wood who lives in the hills with too many guns and a land rover defender
Post #492934 16th Jan 2016 2:26pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Is there maybe some kind of fuel supply issue? Fuel pump, filter, rail etc.
Post #492942 16th Jan 2016 3:03pm
Zeissman
I would not think so as I use the truck yesterday, started first time on the key and only serviced a few months ago I don't think you understand, these boys killed my dog
Post #492949 16th Jan 2016 3:55pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Check all the relays under the drivers seat. This sounds like a common presentation of when one of then becomes loose. Go and pull them all out and put them back in.
Post #492984 16th Jan 2016 6:21pm
