Home > Technical > Problem #2 - steering wheel moved |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
check that 1 of your tyres is not going soft then check all the track rod ends and other steering joints are tight and don't have play in them, best done with a mate or Mrs wobbling the steering wheel back and forth, DEFENDER 90 TDCI XS,
15th Jan 2016 6:48pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
What kind of wheel and boss have you fitted? Is it a fixed wheel to boss that's bolted or a removable one?
15th Jan 2016 6:56pm |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 247 |
The boss is fixed.
I did remove some shims in the swivels last weekend to cure a wheel wobble and have got some new ball joints because the old ones felt a bit 'notchy', but not fitted yet. Would that do it? Also I noticed I'd got a screw in the O/S/F tyre today - but it didnt seem to be deep as I pulled it out with my fingers, so you might have something there also. |
15th Jan 2016 7:51pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2079 |
Did you change the length of the drag link ?
Mo The Land Rover 90 - Many are called, few are chosen. |
15th Jan 2016 8:16pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
Is there anyway for the wheel to rotate against the boss ?
15th Jan 2016 8:25pm |
NJS22 Member Since: 26 Oct 2012 Location: Cornwall Posts: 169 |
When I change wheels I drive round with a ratchet and socket for a couple of week so I can keep adjusting it as I never get it perfect first time. 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure 2015 Range Rover Sport 1971 Range Rover 2 Door Wife won't let me have any more...!!! |
15th Jan 2016 8:59pm |
No......should I have done?
No it's solid When I change wheels I drive round with a ratchet and socket for a couple of week so I can keep adjusting it as I never get it perfect first time. I take it you mean steering wheels? But mine has changed without undoing the boss nut! Also checked the tyres and no pressure loss. |
15th Jan 2016 11:20pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
The wheel cannot shift on the splined shaft. Similarly there is no link to the steering box that can shift.
However, if you have removed shims off one of the swivels, that will effect the toe, which could make the steering pretty imprecise, Depending on the camber of the road, your dead centre postion will then wander to compensate. Get the toe checked. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
16th Jan 2016 7:36am |
RockJaw Member Since: 15 Oct 2013 Location: United States Posts: 317 |
10 O'clock to 11 O' Clock? Are you sure you didn't set it to the clock on your dash? ****CENSORED**** |
16th Jan 2016 8:12am |
I think Ive knackered the swivel bearings fixing my last problem . When I put my hand under to feel the balljoints I got a hand full of swivel grease.
I had to bash the bejesus out of the drive shafts to free the rusted on drive flange and I think thats done it. I will need to strip both sides completely to check their condition. Whats the concensus on the quality of the swivel rebuild kits atm? The usual suspects all seem to sell cheapish full Britpart kits or ones with Timken bearings for a bit more. But are the seals different also? Also shall I change the wheel bearings while in there? They dont seem loose or noisey but I wonder if Ive given them some hammer also. Thanks for your help peeps Nick Last edited by Leviathan on 16th Jan 2016 5:08pm. Edited 1 time in total |
16th Jan 2016 12:21pm |
Confirmed my fears that the top swivel bearing race has collapsed and the swivel ball is pitted also.
I'm going to replace everything. Are britpart kits OK? Any recommendations for suppliers? Nick |
16th Jan 2016 5:07pm |
