Home > Technical > fixing rear ladder captive nut or tapped crossmember ??????
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hi
I have just purchased a rear ladder that hangs in the rear gutter and picks up the 2 torque fixings at the bottom of the rear panel,
Are the nuts captive or is the rear crossmember tapped or neither??? any help would be appreciated.
Many Thanks
Lee
Post #486001 27th Dec 2015 10:31pm
miker
On all the ones I've seen its bolted through to loose nuts on the inside
Post #486005 27th Dec 2015 10:39pm
Leeroy
Thanks miker I will try and fix it tomorrow just need to mark and drill the ladder plate to catch the torque fixings
Many Thanks
Lee
Post #486008 27th Dec 2015 10:42pm
Leeroy
Tapped if anyone is fitting one in the future Razz
Ladder all fitted now not sure on it though it might grow on me
Post #486197 28th Dec 2015 1:30pm
miker
Well, I guess they changed it since mine was built in 199!
Although I guess the change could have happened when they went from having the Xmember 'tabs' on the outside to on the inside of the body.
Post #486783 30th Dec 2015 2:28am
