Home > Technical > Headlights - normal configuration? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
Normal! Flash whilst on dip adds main beam to the mix, so both filaments are lit.
It's actually totally normal on almost all (pre-computer) vehicles. |
25th Dec 2015 9:57pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Yup. Due to the defender having h4 dual filament bulbs, you can't run both filaments continuously, the bulb will overheat.
On a flash its fine and boils down to the mechanics of the switch. |
25th Dec 2015 9:58pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Ok, that's sorted then, thanks for the replies and explanation, especially on Christmas Day!
Cheers |
25th Dec 2015 10:37pm |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 622 |
Hi Lambley, how/what did you do to get your side lights back, I've just done the mod with the loom to stop my lightswitch from burning out and, like you, lost the side light option, can you point me in the right direction pls.?
cheers Mike ps. merry xmas Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
26th Dec 2015 1:31am |
Hi Mike,
Very easy to sort, just needs the dim dip relay removing and a loop putting in its place, ten min job tops..... Cheers, Paul |
26th Dec 2015 6:59am |
Thanks Paul, I'll try that
Job done, works a treat, thanks again Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
26th Dec 2015 4:59pm |
