Home > Td5 > TD5 Build spec |
Doubtful, when I looked mine up it said that there was no tc and abs. Well it has and I don't think that anyone would go to the effort of fitting that lot on after it came out of the factory.
21st Dec 2015 5:27pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I don't think land rover has ever offered locking axle diffs electronically or otherwise from the factory on defenders.
Special vehicles - yes quite possibly but not on standard ones. Would love to be wrong though Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
21st Dec 2015 5:41pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I got a similar spec list for my 2004 90, including the "LOCKING REAR AXLE - E DIFF", just before I collected it.
I got all excited thinking it had some extra goodies over and above the Overdrive and stage 2 remap that I already knew about - all in vain But it also shows, amongst other things - "LESS ANTI-LOCK BRAKES" which it does have all to be taken with a pinch of salt I think |
21st Dec 2015 6:23pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
What's that diff manufacturer called who recently were bought out by Allmakes ? Don't they make an e locking diff that may have been used by Special Vehicles.
21st Dec 2015 6:51pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 625 |
Sorry for jumping onto a TD5 thread with TDi question.
I got similar information back from Solihull 3.54 FINAL DRIVE RATIO 110 INCH/2794MM WHEELBASE 2650 LB. FRONT AXLE 3850 LB(1750 KG) REAR AXLE ASY 6720 LB. GVW DIESEL FUEL CAPABILITY LOCKING REAR AXLE - E DIFF POWER 4-WHEEL DISC SOLIHULL ASSEMBLY (UK) LESS ANTI-LOCK BRAKES I can confirm that Lamp Guards were also fitted through our Special Vehicle Operations Facility. Are we convinced that the E DIFF bit s a corruption on their system. Possibly for Salisbury axle? Did the other details check out as correct for you? Mine does have discs but not ABS. 1995 Defender 110 CSW 1971 SIIA Lightweight |
5th Sep 2016 9:36am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6482 |
Most likely a build code that is shared with the "E DIFF" on another vehicle (e.g. Disco 3) and there is no Defender translation for it. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
5th Sep 2016 9:51am |
