- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Clutch master cylinder |
chiefstoker
Hi, jumped in the landy today to be greeted with a small drip of fluid on the floor mat, ran my finger up the back of the clutch pedal and assume its a worn seal on the master cylinder.
The vehicle has only done 25,000m but is over 5 yrs old, presumably this is normal for a vehicle of this age.
What is the best replacement part(manufacturer) to minimise this problem?
cheers stoker
15th Oct 2010 6:51pm |
chiefstoker
Cheers DJ
16th Oct 2010 7:50am |
