Home > Puma (Tdci) > Whining/buzzing noise 90 Puma 2.4 pickup |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Might just be normal transfer box whine.
Does it have any oil leaks underneath? Might be low on oil? Don't go by the filler plug on the gearbox though as it has a different level arrangement than earlier versions! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
8th Dec 2015 2:22pm |
Jamesjames999 Member Since: 16 Jul 2015 Location: Warwick Posts: 15 |
Thanks for the reply, and no I don't think it's normal at all, only done 8000 miles and it's just started doing it loudly out of the blue. Also it hasn't lost any oil always keep an eye out for oil
Thanks James |
9th Dec 2015 10:16pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
James
Get it back to the dealers if it's only 8k on the clock. They should do it even if its out of warranty with only that may miles on worth a try and a call first. Has it got FSH Can you fill in your profile with your car details it helps everyone see what car your driving and helps with any questions you may have |
9th Dec 2015 10:22pm |
In the end had to have a whole new transmission box i was away so could not fit myself and the track was needed so it was fixed at our local garage.
Landcover where not keen because of it being a 2011 plate even though it was not hardly any miles which was a right pin in the arse. thanks for you replies though |
13th Jan 2016 11:33am |
