Home > Puma (Tdci) > Help please with EGR
Cheshire110
Hi Folks,
i have exhaust gases in my coolant causing my overheating issue. This is confirmed.
I have no other head gasket symptoms.
As such i suspect, or would at least like to rule out, a leak in the EGR cooler. (where exhaust gases and coolant could therefore mix)
The car is remapped to disable the EGR and it has a blank fitted.
I have drawn the following diagram to explain my question... Would a blank at Y be possible to keep exhaust gases out of contact with the coolant?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #479645 6th Dec 2015 4:17pm
dorsetsmith
if you think you have leck in your EGR blank at Y and also bypass egr on the coolant side too Idea
Post #479648 6th Dec 2015 4:32pm
Cheshire110
yep was just thinking that too. I couldn't quite see the hoses for the coolant. Is it possible to join them together? Cheers, David
Post #479651 6th Dec 2015 4:36pm
dorsetsmith
if your EGR cooler look like this one YES
coolant pipes in top and bottom
Post #479653 6th Dec 2015 4:50pm
Cheshire110
thanks, really appreciate your help.
I can't really tell if mine looks like this as its crammed behind the engine but if that is the standard 2.4 one than id imagine it would be?
certainly looks like how i imagine it would look judging from what i can see at the exhaust manifold end Cheers, David
Post #479655 6th Dec 2015 4:53pm
Caterham
yes.
mine is blanked at point 'Y'.
I'm thinking however it's unlikely to be within the cooler - but what do I know?
good luck.
Post #479659 6th Dec 2015 5:03pm
Cheshire110
Thanks Caterham, will blank mine at Y anyway. This is where other cars are blanked anyway.
yep I've just got to the point where I want to rule it out fully, and it shouldn't be too hard a job to do. Cheers, David
Post #479662 6th Dec 2015 5:06pm
dorsetsmith
are you losing coolant ?
Post #479664 6th Dec 2015 5:14pm
Cheshire110
Not at any worrying rate. Only a little by overpressurising and losing it out the cap. Cheers, David
Post #479728 6th Dec 2015 7:19pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Very common personally blank y and bypass cooler with hoses
As water getting into the engine in other cases has caused to hydraulic
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #479734 6th Dec 2015 7:43pm
Cheshire110
Thanks Steve 👍 Cheers, David
Post #479763 6th Dec 2015 8:39pm
Cheshire110
What would I need to connect the hoses together? Cheers, David
Post #479765 6th Dec 2015 8:40pm
dorsetsmith
Post #479779 6th Dec 2015 9:04pm
Cheshire110
Perfect thanks! I could picture these but had no idea what they were called or how to find them! Thumbs Up Cheers, David
Post #479780 6th Dec 2015 9:13pm
shaggydog
I used them on my webasto install.
Very good bit of kit for not much money, just remember to put the jubilee clips on before you connect as once it is past one barb you wont get the Censored apart again! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #479781 6th Dec 2015 9:13pm
