Home > Technical > Juddering Puma |
A known issue, I believe there is an existing thread or two about it on here somewhere. Steve.
2nd Dec 2015 1:05pm |
There are indeed....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Dec 2015 2:03pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
firstly lets hope it's nothing to do with petrol.
as ever it's probably going to through you off on a wild goose chase but might be worth checking all the same - I only found this recently and have owned the def since new and bar 2 services have done all the filter changes myself........ is the fuel filter on properly? below shows 3 marks. 1st being where you engage the filter and the 3rd being fully fitted. 2nd mark being where mine was fitted. no cost potential fix so worth a try. good luck. |
2nd Dec 2015 3:36pm |
andy---doe Member Since: 14 Mar 2015 Location: Yorkshire Posts: 188 |
I did try a search under judder juddering jumping kangaroo and got no results
K9F - thanks for the link Caterham - thanks I will mention that to the dealer, but it did this before the recent first service so I doubt it will be that |
2nd Dec 2015 4:13pm |
I may be barking up the wrong tree , but filled it up today and added some Redex diesel additive to see if that makes any difference
2nd Dec 2015 4:16pm |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
My 2.4 occasionally does these little surges, especially when cold. Driving at very low revs while feathering the throttle when cold does it and I either change down or just give it a bit more right foot and it will go.
3rd Dec 2015 7:22am |
Wheel Member Since: 29 May 2014 Location: Essex Posts: 232 |
Morning Gents,
I thought this was due to it being fly by wire and the "mismatch" between the two at low revs and speed. It was a little annoying at first but happens less and less as you get used to it. I didn't think this was considered a fault as such and I've just adapted my driving to work around it. I'm interested to know if anyone has had this looked at by a dealer and have had it fixed. Mark |
3rd Dec 2015 9:37am |
