Home > My Defender > Santorini 90 Defender |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
Love the additions you have been making mate!
7th Sep 2017 1:30pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Looks great! Do you want to come and polish mine?! I have plenty of hobnobs!! James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
8th Sep 2017 2:26pm |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
As tempting as that is...
Got to polish my new track fairings in the coming week and the Mrs car is due too; i will be all polshed for while after that! Takes about 5 hours but looking back it after makes it worth it and a good binding session tonapprciate its curves or lack of. |
8th Sep 2017 5:41pm |
I thought the ag wheel sealer wasn't meant to be used on black wheels? Ray
8th Sep 2017 6:17pm |
Nothing i can find on that...
Mine are perfect with onr application yearly so far. |
9th Sep 2017 10:17am |
So i got some TruckLitr phase 2 LED headlights.
Been wanting them for years and finally pulled the plug after driving in the dark at the minute with the terrible standard headlights. They really are great at night and look much cleaner at the front. Also put the car to used and harrowed the local manage. Click image to enlarge Click image to enlarge |
23rd Dec 2017 11:24am |
Like them, look great! James
24th Dec 2017 2:20pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
does the spare wheel not cause any problems with the back door? Ie kill the hinges Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
25th Dec 2017 12:05am |
No problem with mine at all - But that will be something with age, mileage and road conditions that assist in dropping the door.
3rd Jan 2018 1:42pm |
my door frame has cracked in various places and the door skins come away. Only the force of the defender that's keeping the door together or rust Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
3rd Jan 2018 2:39pm |
Been a long time since posting but happy to say I still have my Defender and loving it as always.
First of all replaced the Bonnet badge with the genuine Land Rover Defender badge. Not much difference but you can tell if you know and the replica peeled so know this will last and it should for what it cost! Have replaced the side lights with Osram cool white versions to exactly match the TruckLites Click image to enlarge Click image to enlarge |
1st Dec 2019 9:29pm |
Moved to stainless steel screws and bolts all over. Starting with the headlight, grill side screws and slam panel. If you purchase floor panel screws they are the correct ones - I could never find the ones needed to replace them and took a long time to find them!
1st Dec 2019 9:34pm |
Purchased Naketenanga door bolts a while a go and finally found time to run round and replace all the rusty oem ones. Actually takes a while to Unscrew the original and put these. The hardest part is removing the paste from the bolt head edges!
Also managed to strip the torx centre on on and needed to get some kit to remove it. Took an hour but got that bolt out in the end! The biggest change though is adding Perei rear led lights. Travelling up to York and seeing the back of other Defenders it really shows how poor the standard rear lights are. Always wanted these for many years and finally did it 😁 Click image to enlarge Click image to enlarge Click image to enlarge |
1st Dec 2019 9:44pm |
Final additions are the slam panel stainless bolts, bonnet stainless bolts and Rear mud flap brackets and new mirror arms.
The joy of a Defender and annual fettling! Click image to enlarge Click image to enlarge Click image to enlarge |
1st Dec 2019 9:48pm |
