Home > Maintenance & Modifications > Waterproof surface mount socket |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 486 |
Have a look at this post - http://www.defender2.net/forum/post449301.html#449301 Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
19th Nov 2015 7:07pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
Go for the Buccaneer connection, The Royal National Lifeboat Institution use them on all their boats from the D class inshore to the lattest Shannon Class Off shore, We NEVER have an issue with them if used correctly. Only issues we get is people not doing up the collar then pulling the connector apart when using search lights or overtighting the dust and thus being a to remove. Handy hint for the dust cover, Its castleated and there is a keyway for it in the Male socket so you put that over the top and turn lot simpler. We also pack outs with GP marine grease.
19th Nov 2015 7:38pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
I was considering same solution for my roof tent. Ended up with cord extension from the cigarette lighter socket. Routing any place through a door (rubber gasket does not damage the cable nor cable do any wrong to closing a door) and through a gap on tent's hinge. Splitter in the tent and all my electrical stuff and lighting works perfect! Janusz
www.yahodeville.com |
19th Nov 2015 7:45pm |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 |
I bought that same connector for my spotlight roof bar. I think its too big and looks a bit pap. Am currently trying to source another sort with a 90Deg connection to keep it low profile. The best I could fins was these... http://www.bulgin.com/front-panel-mount-co...ocket.html http://www.bulgin.com/right-angle-overmoul...-plug.html The entire catalog is here... http://www.bulgin.com/media/import/Web_Catalogue.pdf |
19th Nov 2015 10:54pm |
Krissvdh Member Since: 18 Mar 2015 Location: Rutland Posts: 12 |
The Bulgin connectors are exactly what i was looking for thanks chaps. Outstanding result!
19th Nov 2015 11:10pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 402 |
Did anyone find where to buy you right angle Bulgin Buccaneer plug? RS don't seem to stock them...
16th Jan 2017 8:05pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
This maybe of interest ?
https://shop.landreiziger.nl/modificatie/m...frack.html |
16th Jan 2017 8:34pm |
I was hoping sub €100 euros for both male and female parts.
Thanks though |
16th Jan 2017 9:24pm |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 622 |
did anyone get both plug and socket? if so, what was the total cost? cheers Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
17th Jan 2017 3:07am |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
That's a kit including cables, relay etc to hook up lights. Just the connectors would be cheaper. It's probably a bit hard to find if you don't speak dutch, so here are the actual connectors themselves: https://shop.landreiziger.nl/waterdichte-connector-kabel-bus.html (plug) https://shop.landreiziger.nl/bus-met-kabel-4-polig-female.html (plug with 2m cable) https://shop.landreiziger.nl/waterdichte-c...polig.html (same but at 90 deg) https://shop.landreiziger.nl/waterdichte-c...ekker.html (socket) https://shop.landreiziger.nl/waterdichte-c...basis.html (optional 90 degrees mounting piece) https://shop.landreiziger.nl/waterdichte-c...hting.html (seal) They are IP67 and max 16A. You also might want to check the magcode system, which landreiziger has on offer too. Magcode pro can handle 25A. I guess it's not ment to remain connected inn all weather 24/7 but that's just a guess tbh. https://shop.landreiziger.nl/catalogsearch/result/?q=Magcode Hope this helps. Greetings, Joris |
17th Jan 2017 3:55am |
http://www.mobilecentre.co.uk/ |
17th Jan 2017 9:58am |
