![]() | Home > Off Topic > Rotating photos? |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038 ![]() ![]() |
For some reason, no matter what the orientation of my iphone when I take photos, when I upload them they get rotated, and the file sizes from my iPone 6 and 6 plus are so big, the site cannot rotate them.
The only way I can ensure they are the correct way round is to upload them onto my pc from the phone, then use Paintshop Pro to scale it down and rotate. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
On the iPad/iPhone Select edit when viewing image, you will get a tool bar at bottom of image, there is a rotate tab.
This is a bit of a lottery, if my chosen image is upside down I have to rotate it 360, back to the original orientation to get the image correct for uploading ![]() I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
Here are some screen shots
One normal and then rotated. ![]() Click image to enlarge ![]() Click image to enlarge Sod's law these 2 loaded at the correct orientation !! ![]() I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Thanks very much chaps.
![]() I will give it a go ![]() Wanted, Forward Control Anything considered. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
This is something I have trialled a fix for on DISCO3, I just need some time to get it implemented here.
It doesn't happen often Martin, it seems to be just getting photos the right way on the iPad helps!
Thanks very much ![]() Wanted, Forward Control Anything considered. |
