Home > Technical > Location of spring colour codes
Cupboard
I think my Defender has stiffer springs than I want, and to check that I've been looking for the colour codes on my current springs. I've been looking for two vertical stripes of colour down the spring somewhere, but I can't find what I'm looking for.
1) is that the correct thing to be looking for? Are there any suggestions on what I might be doing wrong? I've cleaned them and gone all around them with my hands. There don't seem to be any markings.
2) is there any other way of telling what sort of springs they might be? They're just black!
3) are there any after market springs that are just black? It's entirely possible that something different was fitted as it seems to have been worked hard in a previous life and had the mother of all roof boxes on it.
Post #468107 31st Oct 2015 4:13pm
dorsetsmith
Post #468110 31st Oct 2015 4:32pm
Cupboard
Yes, that's the information I'm trying to find, I just can't find the actual colour codes on the springs I've already got!
Post #468113 31st Oct 2015 4:49pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
On mine, the colours are just daubed down the length of the spring. Nothing very pretty, but quite obvious on new/clean springs. If they are very muddy or rusty you might struggle to see them (if they are that old they have probably gone soft anyway...!).
cheers
simon
Post #468117 31st Oct 2015 5:08pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Perfect timing.... photo just posted on this thread... http://www.defender2.net/forum/topic39672.html Thumbs Up
Post #468121 31st Oct 2015 5:12pm
15' Puma's have springs that are marked the same in the front and different on the back.
So a front match and rear match.
They are not handed left or right.
Early Pumas were handed I believe but mine is running aftermarket springs anyway which I am to change to genuine so it's pointless...
Post #468124 31st Oct 2015 5:43pm
couplands
^^^ I think it also differs if you have a HT or CSW. Then there are HD springs you can order for the HT (which may be the same as the CSW std springs).
Sounds like Cupboard has aftermarket springs, there is a chart somewhere on here that gives you the length and rating of the springs, so I guess you could measure them...? The chart also includes some aftermarket springs (like OME).
cheers
simon
EDIT: Here's a link to a chart with spring lengths and llbs ratings http://www.red90.ca/rovers/springinfo.html
Post #468125 31st Oct 2015 5:47pm
Cupboard
Hmm.
Those pictures make the markings look nice and obvious. Mine aren't.
However in Def90's post on the other thread, they're only marked in one place and it's entirely possible I've missed something like that.
I think I might get it in the workshop tomorrow and take a wheel off to get a better look, if I still can't find anything then I'll order some normal ones and swap them over.
Thanks for the help Thumbs Up
Edit: just thinking, I'm sure when I asked what "standard" springs were a month or so ago someone posted a different table that had the differences between a 110 HT, CSW, USW and 5 seat CSW.
Edit 2: here we go:
epictrail wrote:
Here's a couple of links to Spring rates. Also what tyre pressure are you running on the rear? Might be too high...
Post #468152 31st Oct 2015 7:25pm
Cupboard
Finally had some time in the workshop, and I found the colours Smile
I'm not surprised I couldn't find them before.
Presumably I want to change to white/green/green.
Post #472042 12th Nov 2015 9:07pm
YOLO110
Australia
So!
I am now very confused as my front driver side spring has a colour combo that is not on the list!
Red/Green/Yellow!
Are these HD springs?
I do have vented front disks too!
Does anyone know please!
Cheers. Rolling Eyes YOLO... You Only Live Once...
Post #499794 3rd Feb 2016 8:07am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi YOLO110
I believe that's a Red/Green/Orange paint code on that spring !
Late model 90 Front passenger side on a RHD vehicle.
The HD refers to the rear spring rates.
Post #499798 3rd Feb 2016 8:36am
YOLO110
Australia
Ok... it could indeed be orange?
But it is on the drivers side on a RHD vehicle!??!
Unless being 'Downunder' also means swapping sides too! Laughing
Confused by this... IT would seem it does have HD springs, the vented disks also support this?
Pete. YOLO... You Only Live Once...
Post #499838 3rd Feb 2016 11:00am
Def90
Hi YOLO110
Just taken a look at my 2015my RHD 90 XS and it appears to have
Red/Green/Orange front springs on both sides !
What spring paint code do you have fitted to your passenger side ?
Post #499848 3rd Feb 2016 11:25am
geobloke
There is another source of spring colour coding which gives a whole heap more information at Red90.ca;
Post #499850 3rd Feb 2016 11:29am
Dave-H
Just for info fella's ...
All these 'spring guides' were written long before the puma came about, so the colour codes listed do not apply to puma models Surprised
Puma springs are not 'handed' [although on early models they were, a trend soon discontinued as It served no purpose], It's the same colour code for both springs on each axle. Guns and Landrovers .... anything else is irrelevant.
Post #499872 3rd Feb 2016 12:37pm
