Home > Wheels & Tyres > Continental cross contact noisy? |
yep and they just get worse.
29th Oct 2015 4:59pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
My Disco 3 had a new rear diff at 1500 miles because it whined- so don't rule anything out. Must admit hadn't noticed my 90's OEM tyres howling.
29th Oct 2015 5:14pm |
alby Member Since: 25 Dec 2014 Location: The Shire Posts: 159 |
My defender originally had steel wheels and latitude cross tyres, they were in general quiet, however i found they used to howl a bits of road with smooth, recently relaid tarmac (a rare thing round these parts!!) they were run at be book pressures for a light load.
Not as bad as the howl from a set of goodyear xtragrips, but a noticeable howl. Have now fitted boosts with conti cross contacts (again set to the book pressure for light load) have found they don't do it. |
29th Oct 2015 5:35pm |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
I have these tyres and find them extremely quiet - one of the points of keeping them on there.
Check your tyre pressures as they might have something to do with it. Also check your alignment - one thing I have seen is opposite wear on tyres so run your hands on the tread from the front of the car to back, if you find it catches then that can be a cause - swap them round and after a few 100 it should quieten down. |
29th Oct 2015 6:54pm |
Also, very unlikely but remove anything stuck in the tread.
I have had a few stones in mine and drives me crazy on smooth roads, I have to always pick them all out! |
29th Oct 2015 7:04pm |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 |
It does get worse if I'm carrying a heavy load and varies with different road surfaces which made me think it is the tyres. I've had a 90, a Def TD5 and a 300 Tdi Disco with BFG ATs and GG ATs, all 265/75 and all were good. It's not really intrusive but annoyingly noticeable.
Thinking of changing to 265/75 AT2 so if anyone in the market for 5 Contis with 16k miles, spare unused...........let me know. |
29th Oct 2015 9:50pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
I have a Defender which came with these tyres as new. Nice and quiet until at about 15K miles I thought I'd move them around to even out the wear and included the new spare in the juggling act. - The result was significantly increased road noise, presumably because of the strange wear pattern that tends to develop on chunky 4 X 4 tyres, you could see the even but lumpy wear pattern poking through the canvas spare wheel cover.
So my guess is that unless all 4 of your tyres have been worn evenly from new and NOT swapped about, you will get noise from them. It appears to be best to fit 4 new ones together, never move them around, (they last long enough anyway) and enjoy the relative but not perfect silence. Cheers, John. 2.2 90 XS 88" Series One Old Norton Minerva |
29th Oct 2015 10:02pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
Got 235/85/16 had them for a couple thousand miles and cant say ive noticed any road noise.
29th Oct 2015 10:29pm |
I have never bothered changing tyres around. As said they last long. Just bought the car so don't know whether they've been rotated ( no wise cracks ). Wouldn't have thought so at !6k miles.
29th Oct 2015 10:55pm |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 331 |
I don't find them noisy except at low speeds on Tarmac!
30th Oct 2015 11:29pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 714 |
Noise wise, 40,000 miles in and I've Not had an issue with mine. I have noticed reduced stability even though there is quite a bit of tread left.
9th Nov 2015 9:31pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3753 |
In view of the relatively "large" tread relative to a road tyre, I reckon they're very good. 31,000ks on ours, I'd buy 'em again.
Pickles. |
9th Nov 2015 9:38pm |
WhiskyJackR Member Since: 25 Nov 2014 Location: Lizard Posts: 159 |
For the type of tyres they are pretty much what I expected in terms of noise. They don't bother me although my friend drove it and he complained they were much noisier than the tyres on his Range Rover Westminster!!! I didn't have a response
I've covered 7000 miles now and the wheels have not been moved around the vehicle. Any farther South and I'll need to trade the Defender in for a Landing Craft |
9th Nov 2015 11:22pm |
PeeWee Member Since: 13 Apr 2017 Location: Somersetty Posts: 17 |
Noisy? when the Cross C's are fitted my 110 sounds as if it has a collection of bad wheel bearings.
The only reason I know that it is not the bearings is that the BFGs that I use in winter (I work in and around ski resorts) are so much quieter. Cab someone suggest a a "summer" tyre that is as quiet running as the BFGs? Cheers PeeWee |
13th Apr 2017 9:02pm |
