Home > Technical > Reverse light |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Have you seen this thread?
http://www.defender2.net/forum/topic32834....p;start=15 |
25th Oct 2015 7:24pm |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
Double Labcraft scene light means problem solved; in fact I probably now have more light going backwards, than most people have going forwards "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows." |
25th Oct 2015 11:24pm |
BossHog Member Since: 28 Jun 2013 Location: Fylde Coast Posts: 185 |
Thanks for the link, I wasn't aware of the scene light, think that's the way to go.
29th Oct 2015 10:07pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
You might want to make sure that the reversing light switch is properly screwed into the gearbox. It's not unknown for it to be loose, in which case the light will be intermittent.
29th Oct 2015 11:39pm |
BW thanks for that I will check the switch, now I know where to look!
31st Oct 2015 9:51am |
